Old 05-04-2015, 04:02 PM
gt383mag's Avatar
gt383mag gt383mag is offline
Default PTO size
I re-powered my new to me 2082, which had a mag 20 in it, with a CH18 from a 1864. The CH has a larger diameter PTO pulley than the mag 20 did. Here's the dilemma, the 50c that came with the super, the mule drive is pretty bad off. I have a 48GT deck from a 1440. I'm pretty sure its part number 317-190-100. Although the numbers on it are 317190, the deck and mule are in great shape but the belt isn't going to fit. Partstree says this deck will fit my 2082 and use a 5/8 x 92 belt but that's with the smaller pulley. It says it will fit all these tractors:
Cub Cadet 1641 S/N 821,060 - 880,000
Cub Cadet 1641 S/N 880,001 - 899,000
Cub Cadet 1782 S/N 821,060 - 889,000
Cub Cadet 1861 S/N 821,060 - 836,000
Cub Cadet 1862 S/N 821,060 - 836,000
Cub Cadet 1863 S/N 836,001 - 880,000
Cub Cadet 1863 S/N 880,001 - 899,000
Cub Cadet 1864 S/N 836,001 - 880,000
Cub Cadet 1864 S/N 880,001 - 899,000
Cub Cadet 2082 S/N 821,060 - 836,000
Cub Cadet 2084 S/N 836,000 - 864,500
Cub Cadet 2086 S/N 880,001 - 899,000
Cub Cadet 2182 S/N 821,060 - 880,000
Cub Cadet 2284 S/N 864,501 - 899,000
Does anyone know did all these tractors have the smaller PTO pulley or were that small and big? On the look-up Partstree, says look at mower adapter 322 or 323, and then for use with the super garden tractor use 954-3001. I believe is a 5/8 x 92. How much difference is there in belt length between the 2 pulleys?
Old 05-04-2015, 06:07 PM
gt383mag's Avatar
ok im guessing that the later model 2082 had the large dia. pulley as it calls for a 451 blower and my early model calls for a 450 blower but now has the larger pulley.i mounted up the deck and i had to move the hanger from the front hole to the rear hole on the mule drive to make the rear piece fit onto the brake shaft a B90 belt would fit if it was still in the front hole on the mule. they are 2 inches forward which would make me think the belt should be 4 inches longer? partstree calls out either a 5/8 x 92 or 5/8 x 96.5 any ideas?
Old 05-04-2015, 07:02 PM
Well I think what you have created is basically a 2084. So it looks like you need a 190-322-100 mower adapter with a 754-3047 BELT-V B SEC X95.3. If you have a TSC close by I'd do the old wrap a rope around the pulleys and go see what looks like it will play. The people at TSC love me, I'll buy what looks close and a couple smaller and a couple larger, find out what fits and return the others.
