Old 05-09-2015, 02:25 PM
Daniel1962's Avatar
Daniel1962 Daniel1962 is offline
Default 12 Hp 301 Gov & carb questions for 1st start up
Just about the fire up my new motor, Question What holes does the GOV spring go in on both arms?
Also IS there a procedure for dummies to adjust the 2 screws on the carb?
I see the chart that shows the Factory recommended starting position
thank you
Dave
1976 Cub Cadet 1200 & 44A mower
1964 Cub Cadet 100,
No Attachments at this time, I do have a cart to pull stuff around.
Old 05-09-2015, 02:30 PM
There are two sets of holes.... one on the throttle arm, and one set on the governor arm. "Factory" setting on the governor arm is third from the bottom. On the throttle arm, it's wherever you need it to get the adjustment on the dash to your liking.
As far as tuning the carb, you set the initial setting and tune it from there. Every motor is different, so no, we can't help you. You have to figure it out and tune it to run in the best location. The engine service manual tells you where and how to set the governor spring location, how to reset the governor (which is you have not, you MUST set before start up) and how to tune a carb. You really need to read the book. The PDF file is in the Tech section, just say if you can't find it and we can post a link.
