Old 05-13-2015, 05:28 PM
hogfly hogfly is offline
Unhappy 1863 wheel weights
hello all i have a 1863 already had weights on it (190-370-100) i think 75 lbs. a side took them off to have rim guard added went to put them back on 1 side no problem air stem in the center of weight other side does not line up stem drags on weight checked measurement from stem to 1st rod hole differennt on this rim both are armstrong rims not sure if they are oem any one ever cross this before thanks kenny
Old 05-13-2015, 05:41 PM
Just twist the weight a little. Center the stem in the hole for it.
Old 05-13-2015, 06:26 PM
yea i think thats what was done before but its like a 1/14 off they did not have nuts on the inner side of the rim so they could bow the rods and bent the rubber stem right against the weight i now have steel stems and i cant get it right should i redrill the 2 rod holes or modify the weight looks like some kind of concrete thanks all
Old 05-13-2015, 07:14 PM
The bolts don't have to be perfectly straight. Just twist the weight and bolt it on. I don't see what the issue is.
