Old 04-15-2010, 08:13 PM
gazoriginal gazoriginal is offline
Default head gasket
i'm replacing the head gasket on a cub cadet original. everything came apart great, got new head gaskets, new head bolts. thought i was ready to put everything back together. i was reading my owners manual about the torque of the head bolts when i read that they recommend soaking the head gasket in water before assembly. i have never heard of anything like that. has anybody ever done that, if so, what is the purpose behind soaking the head gasket in water? thanks
Old 04-15-2010, 08:44 PM
Smile
ok thanks. it just didnt make any sense to me
Old 04-15-2010, 09:30 PM
Did you check your head on piece of glass to see if it was flat? Are you using new head bolts?
Old 04-16-2010, 12:32 AM
johncub7172's Avatar
i did not know they did that to a head gasket back then. lol! :biggrin2.gif:
Old 04-16-2010, 07:22 AM
i have not put it back together yet, but i have not checked the head yet. i do have new head bolts. would a local machine shop be able so resurface a head, or is there a way i can do it at home? ( maybe like a belt sander?) thanks
Old 04-16-2010, 08:06 AM
Get yourself a flat sheet of glass and some 220 grit wet/dry sandpaper move the head in circles on it until all of the gasket surface has been cleaned up. This will probably give you a flatter surface than most milling machines.
Old 04-16-2010, 12:08 PM
thanks for the tip. i know what i will be doing this weekend.
Old 04-16-2010, 04:26 PM
matt, great tip. had a spare piece of glass, some 220 grit sand paper, water, and a little patience. looks like i just got it back from a machine shop. thanks again for the tip
Tags
bolts, gasket, head, water
