Old 05-16-2015, 01:29 AM
Default Deck wheels
Where do you all get your deck wheels. These rear ones have been in rough condition since the day I brought it home. But now there pretty much toast.
Cub Cadet IH-479427-R91
WHEEL, 7 IN. GAUGE
Shows they are no longer available. Did a giggle search, and closest was a 6" any thoughts on where to look for new ones? There for a 50A
Thanks
Old 05-16-2015, 02:09 AM
bocephus1991's Avatar
Think ours came from IH/ cub cadet years ago just a solid black wheel. I'd think tsc or a farm supply type store would have them. Or go with the replacement ones and move up one mounting hole to adjust for the size difference. A sponser may have what your looking for too. These black wheels are on my 44A
Brian
Old 05-16-2015, 05:16 AM
cubby102's Avatar
cubby102 cubby102 is offline
Would a replacement 7 inch push mower wheels work...if so I'm pretty sure they can even be had at walmart..
Old 05-16-2015, 10:19 AM
Never thought of a push mower wheel
Never measured one to see what size they are. I know my other mowers have 6", and these are 7".
Old 05-16-2015, 03:43 PM
Check with surplus center, they have a bunch of wheels.
http://www.surpluscenter.com/
Old 05-17-2015, 07:55 AM
Daniel1962's Avatar
Daniel1962 Daniel1962 is offline
Default Steel wheels
Last night I found Lowes Has the Arnold brand Steel Wheel 7" diameter
for about $9 each
They also had the Bolt Set for $2.99
Putting these on my 44a
Dave
1976 Cub Cadet 1200 & 44A mower
1964 Cub Cadet 100,
No Attachments at this time, I do have a cart to pull stuff around.
Old 05-17-2015, 01:39 PM
IHCadetCollector's Avatar
IHCadetCollector IHCadetCollector is offline
Any old wheel will do. Just make sure wheel hole diameter meets your sholder bolt diameter. Or just buy new sholder bolts.
I lost track of what I own a long time ago!
Old 05-18-2015, 12:13 AM
Not if I go smaller than 7" unless I drop down to the lowest hole, Right now it's bolted in the second hole from the bottom, so....... if I was to go to the 6" I'd have to use the bottom hole to make it the same. Right?
Old 05-18-2015, 08:13 AM
SGragg SGragg is offline
Inactive Member
In the future, watch out at some of the swap & shops and/or tractor shows you may attend. I found a guy selling 6" replacement wheels for $1 each. Keep your eyes open...
Stanton
1980 IH 782, Kohler M18
IH #1 Cart, original
2015 XT2, Kawasaki 23 HP
