Old 05-18-2015, 06:30 PM
MECH123 MECH123 is offline
Default 149
hello all this is my first post on my 149... when I purchased this I got the tiller, tractor and front mule drive...question is this did cub have 2 different mule drive depending on app... mine has on the right hand side a spring loaded pulley and on left side just flops around. I saw on google search that the tiller drive has two bolts coming out for tensioners ???? im going to try and post pics... I believe its a 1 1a tiller. numbers are gone.... thanks for the help chris
Old 05-18-2015, 09:27 PM
You replace the spring with an adjustable rod with a nut just like is on the other side. Then go back to the spring when you use the mower deck. Or you buy a second mule drive and set it up specifically for the tiller.
Tiller Manual:
http://ccmanuals.info/pdf/1%20Tiller...s%20Manual.pdf
