Old 05-21-2015, 06:18 PM
Daniel1962's Avatar
Daniel1962 Daniel1962 is offline
Default 44a Pulley 4" vs 5"
In my quest today to find the belt for my 1200/44a, My dealer actually has
2 of the 4" pulleys, # IH-126393-C1 brand new Old Stock
He also had the 5". I measured both.
There price is 38$
my question to you guys is just how much better performance can I get with a 4" ?
thank you
Dave
1976 Cub Cadet 1200 & 44A mower
1964 Cub Cadet 100,
No Attachments at this time, I do have a cart to pull stuff around.
Old 05-21-2015, 06:22 PM
jimbob200521's Avatar
I can't give you raw data like % of increase in blade tip speed, HP required to drive 4" vs 5", nor can I give you personal experience from the upgrade. What I CAN give you is plenty of experience with the 5" pulley on the 44A deck. In my opinion (and based off of what I've read by guys that have done it), I'd say it would be beneficial if you cut wet, thick, or tall grass even somewhat regularly. At my current house, I used the 44A deck when I first moved in. For most of the yard, it did just fine; no complaints. But I have a couple areas that grow faster, thicker, and taller than the rest and in those areas, I would have liked a bit more from the deck (being driven by both a KT17 S1 & M18 so HP wasn't the issue) If you keep your yard trim, don't mow wet or anything like that, I wouldn't think there would be a need to upgrade.
That being said, I'm sure others will be along shortly to give some real world experience aka actual help
-Ryan
Old 05-22-2015, 08:45 AM
OldCubby OldCubby is offline
There price is 38$
thank you
Dave
I highly suggest you get the 4" pulley.
Cub Cadet 1250 w/ the K301aqs engine. Restored to 1978
Columbia City, Indiana
Old 05-22-2015, 09:15 AM
The IH-126393-C1 is the correct pulley for the QL tractors with a 44 inch deck.
Old 05-22-2015, 09:30 AM
Daniel1962's Avatar
Ok thats great, What will be the correct Belt?
Thank you
Dave
1964 Cub Cadet 100,
Old 05-22-2015, 10:15 AM
j4c11's Avatar
j4c11 j4c11 is offline
Dave
Driving a 4" pulley with a 5" PTO would result in a 25% increase in speed, from 3600 rpm to 4500 rpm. Tip speed would increase proportionally.
