Old 05-22-2015, 08:23 AM
Diesel Krazy's Avatar
Diesel Krazy Diesel Krazy is offline
Default 3-point and rear PTO compatibility
Hello. I am looking to find out if this will work without any issues. I have a 2182 with a 3-point and rear PTO. I am going to be picking up a 1572 and I am wondering if the 3-point and rear PTO from the 2182 will fit on the 1572. I looked on Parts Tree and it shows the same part numbers for both machines. When I do the Swap I will be installing a set of Sam Mac rear braces. I am just looking to find out if someone has done this before and if everything will bolt up with no modifications or additional parts. I will be ordering the rear braces next week as soon as I pick up the 1572 and want to be sure nothing else is needed to make the swap. Thanks for any help and opinions.
Original- Wheel Weights, AG tires, Brinly Sleeve Hitch, #2 Cart
882- 50c Mower Deck
2182- 60c Mower Deck, Rear PTO, Cat 0 3-Point, Brinly 60" rear blade
Case 646 FEL
Case 446
Old 05-22-2015, 09:43 AM
It should play with no problems. You'll need 6 longer bolts than come in the kit for the lower attachment points for the lower links. This is my 2182 with the 3 point and the brace kit.
Old 05-27-2015, 10:32 PM
Thanks for the information.
882- 50c Mower Deck
Case 646 FEL
Case 446
Old 05-28-2015, 10:32 AM
Ih man Ih man is offline
I don't believe the rear brace will work along with having a 3 pt, without modifications, because they share the same mounting bolts on the bottom of the axle housing. I am currently looking into this for my 1772 w/ 3pt, have the brackets just haven't got them to fit yet. Maybe someone has done this already and can elaborate.
Old 05-28-2015, 10:51 AM
They fit just fine with the brace, look at post #2.
Old 05-28-2015, 03:02 PM
Well... I clearly misread #2 and didn't notice the brace in the pic sorry guys
Old 05-15-2016, 11:24 PM
stevescub stevescub is offline
Hi Sam. I'm newbie. And seeing you have a 3pt hitch on your 2182. I have just acquired a 2182 790hr for 1993yr 60" hayban deck. I want to put 3pt hitch on mine. Where does one get one and how expensive?
I live southern il and want to put blade on for winter pushing snow and/or drag my gravel driveway. Also, want to make a FEL for snow removal and move dirt around, understanding 200lb lift and easy does it. ANy suggestions on size and length of cyclinders?
Old 05-16-2016, 12:43 AM
xtreme motorworks, something like that.
Old 05-16-2016, 09:02 AM
I suggest the Ruegg 3 point hitch. It's a copy of the factory hitch.
http://www.rueggmfg.com/
You'll need to call Bill, he's mostly a John Deere guy and doesn't list the Cub hitch.
One of our members Rescue11 is developing a 3 point that looks interesting, you may want to PM him.
