when I picked up my 1864 the guy threw in the 3 point bracket and lift rod but not sure how the rod hooks up on the tractor. that is all he had so I might make the other stuff or get it from extreme. any help or even pictures on the rod connection would be appreciated.
pretty sure the end with the bolts hooks up to the front at cylinder/rockshaft the other end goes into the rear lift and has a slot in it so the rear lift will float
edit not so sure that lift bar is the rite one for your tractor not so sure its supposta have bolt holes
982D kwik-way loader w/3 spool control and front and rear remotes,2182, 1812 cat 0, 1440 puller, 3185 grass killer, 2x 450s, QA42, 364, tiller |
Looks like it has one threaded hole in the center, that one is for manual lift spring assist so I have been told
Is your Cub Manual or hyd lift?? Pull up the parts look up diagrams It's all there, an exploded view in black and white |
An 1864 is hydraulic lift.........
It appears that block is used on manual lift so I just remove that. Problem I have is there seems to be to much of a bend near the front so the bar hits the upper frame.
