Old 05-29-2015, 03:48 PM
CubDieselFan's Avatar
Default Oil Cooler
Has anyone ever put a oil cooler on their Magnums or Commands? As hot as these engines get I think that would help dissipate some of the heat.
Old 05-29-2015, 03:53 PM
jimbob200521's Avatar
I have not personally done it but have looked in to it. Kohler sells a kit to add an oil cooler to the Commands. Below is a link to one of the many online sales of the kit as well as a link to another site that has pictures of someone who installed that kit. Hope this helps!
http://www.mytractorforum.com/19-cub...00-series.html
http://www.ebay.com/itm/like/1416692...lpid=82&chn=ps
-Ryan
Old 05-29-2015, 04:08 PM
My wonder with the oil cooler kit from Kohler is can you increase the hose length between the plate and radiator so you could locate it somewhere else without adversely affecting oil flow/pressure? I'd rather have it up front or even located somewhere under the tunnel cover with an electric fan blowing across it than mounted on the shroud. The reason being is where is that additional hot air going to blow to? Back in the engine compartment so that almost seems counterproductive. Just my for what it's worth. Either way, I like the idea of adding an oil cooler. Just gotta get someone to measure some engine temps over a few weeks then install the kit and compare before and after to see if it actually makes a difference.
-Ryan
Old 05-29-2015, 04:38 PM
I am thinking the same thing. I would like to have it out of the engine compartment. The purpose to me would get as much heat away from the engine. maybe someone on here as installed one.
Old 05-29-2015, 04:54 PM
RR1862CC's Avatar
RR1862CC RR1862CC is offline
You would get some cooling just from the extra oil capacity the cooler gives you.
Allis Chalmers 416
Massey Ferguson MF-8
Brinly 10"plow
Old 05-30-2015, 01:21 PM
TheSaturnV's Avatar
My Massey Ferguson (LegacyXL) has the oil cooler made from short sections of hose and the small rad that mounts right over a hole in the cooling shroud. A lot of air is forced through, seems to work well.
Old 05-31-2015, 01:05 PM
TheSaturnV's Avatar
Kohler Command CH25 btw.
