Old 06-03-2015, 05:39 PM
blee128 blee128 is offline
Default 23hp command
Has anybody used the mwsc adjustable rocker stud kit if so what's ur thoughts on it?
Old 06-04-2015, 05:53 AM
Can't go wrong with anything MWSC.
I have no other comments.
Old 06-04-2015, 06:53 AM
Commands come with hydraulic lifters. If you convert to solid lifters then you need the adjustable rockers. Are you building a puller engine?
Old 06-04-2015, 10:26 AM
Yea it's gonna be a pulling motor
Old 06-04-2015, 10:58 AM
Just keep in mind that you will need to change the lifters to solids or roller lifters if you are going to use the adjustable rockers.
