Old 06-06-2015, 11:46 AM
jcrews's Avatar
jcrews jcrews is offline
Default Engine addicted to ether
Hello it's been a while since I've posted I do read posts though. My 782 is addicted to ether with a cold start. Does anyone know of an easy fix? I've read that the rings could be wearing out but that was on Diesel engines. Any suggestion will be greatly appreciated.
I H Pushmower,100,104,124,1450,1650,782,982,154 LoBoy,185 LoBoy,2 Farmall A's , Farmall H, and 8 IH trucks
Old 06-06-2015, 12:28 PM
What have you done to try and fix the problem? Anything?
Old 06-07-2015, 06:43 PM
jcrews's Avatar
Hi well I removed the carburetor and cleaned all the ports to make sure there were no blockages, new air filter. I ran marvel mystery oil through the carburetor but nothing else.
Old 06-07-2015, 06:59 PM
Billy-O's Avatar
Billy-O Billy-O is offline
Did you do anything with the points/timing, check/replace spark plug.....that sort of stuff?
Plow blade
#2 Cart
QA36 snowthower
Old 06-07-2015, 07:35 PM
I put in new points and a condenser. My manual lift 125 was real PITA to start until I installed new points and got them adjusted correctly.
It starts much easier now.
Jeff
edit, if your engine doesn't have points, verify timing
Old 06-07-2015, 10:27 PM
jcrews's Avatar
I installed new plugs this season but have not changed any points on this engine (M18)Kohler . I have 3 cub cadets with k series engines in addition to 2 more and have replaced & adjusted the points on them but I don't recall ever seeing the points on the m18. But that sounds simple enough thanks for the help
Old 06-07-2015, 11:12 PM
M18's don't have points.
What spark plugs did you use?
How many hours on the motor?
Old 06-08-2015, 06:57 AM
jcrews's Avatar
NGK4 UR4 spark plugs
Hours obviously many engine installed by po
Old 06-08-2015, 06:25 PM
REDDHOGG REDDHOGG is offline
Bad fuel pump ?
Old 06-08-2015, 10:54 PM
Originally Posted by REDDHOGG View Post
Bad fuel pump ?
Still ought to start with the fuel in the carb. Plus, usually when the pumps fail it puts gas in the oil..... badly.
