Old 06-08-2015, 10:40 PM
IHinIN IHinIN is offline
Default Model 100 refurb
I've finally begun tearing down my 100 to repaint and rewire it. The engine (K301) may get rebuilt as well since it smokes a little at startup and has a slight knock when under a moderate load. I already have a set of Maple-Hunter decals I bought about 5 yrs ago when I originally planned to paint it. It needs a new hood and there are a few extra holes in the tower that need welded shut. I don't plan for this to be as thorough, or time consuming, of a repaint as my red 129 since the 100 will retain the factory paint scheme.
On to the before and current progress pics.
Old 06-08-2015, 11:37 PM
Let the fun begin.
What brand are those front tires?
Old 06-09-2015, 04:56 AM
Let the fun begin.
They are Carlisle Field Trax. They discontinued the 16/6.5/8 size about the time I bought them.
Old 06-09-2015, 05:19 AM
Rdrnek Rdrnek is offline
Looking forward to watching your progress.
-Bob-
149 w/48"deck, 2 100s and and 2 ugly "O"s parts 104
Old 06-09-2015, 10:53 PM
Got the engine pulled and started disassembly so that I can measure the bore and rod journal to see what piston and rod I'll need for the rebuild.
There was quite a bit of carbon around the valves and spark plug which I expected since it was using about 6 oz of oil per hour of run time. The top of the piston and bottom of the head were covered in oil.
The piston is definitely in need of replacement going by the wear near the exhaust valve.
The ring end gap checks .070" which seams excessive.
Old 06-10-2015, 09:24 AM
she runnin a little lean at some point??... tractor is in really good shape though for its age... some one took care of it... glad to see her get treated right.. knowing your stuff, im sure its gonna be sweet...
Old 06-10-2015, 09:45 AM
My dad bought the tractor around 1980 and it's never sat outside since. Part of it has been repainted before because there is paint flaking off of the tower and the original paint underneath is in better shape.
Old 06-10-2015, 07:37 PM
Looked up the specs for the engine and the ring end gap is supposed to be .010"-.020" new and .030" max so it is definitely worn out.
Old 06-12-2015, 06:01 PM
I may not be rebuilding my K301 after all. A friend offered to sell me his 149 for a good price. He was told by a guy we work with that it was rebuilt with a Kohler piston and rod and only has about 50 hrs on it. He hasn't had it running though since the S/G is bad. I might take my S/G over to his house and see if I can get it running and buy it. Then, I'll either paint the engine red to drop into my 129 to make it a 149 again or put the K321 in my 100.
Old 06-12-2015, 06:49 PM
I'd put the 14in the 100, should make one heck of a plow tractor. I'm about to get a 14hp to put in my 108.
Pap's 100
Restored 108
1211 Dual Stick
1050
