Old 06-11-2015, 09:41 AM
rdehli rdehli is offline
Default Pulling axles on an 1812
never done this before , whats the best way to remove a rear axle from an 1812 to replace the seal, thnx in advance
Old 06-11-2015, 09:58 AM
Put it on jack stands, drain the oil, remove the rear cover, wheels, brakes, then pop the c-clips in the center of the diff and out they come. Clean everything up, pull the old seals and replace. Then put it back together.
Good time to suction to water out of the axle tubes while you have the axles out.
Old 06-11-2015, 10:22 AM
thanks much
Old 06-11-2015, 10:25 AM
It's all explained in the service manual starting on page 3-25
http://www.onlycubcadets.net/forum/s...ad.php?t=25397
