Old 06-11-2015, 10:24 PM
Default Front Blades are a PITA
For those of us who take off and store a front blade in the summer, they can be a pain.
To save floor space, you pretty much have to stand them up on the face of the blade and keep them close to a wall so the sub-frame has something to lean against. Naturally, every time you get close to it the sub frame wants to fall over and the lift rod will never stay where you want it to.
My remedy for this annoying problem is to drill and cut a small piece of steel and weld it to the sub-frame in such a place that you can attach the "loose" end of the lift rod thereby supporting the sub frame preventing it from falling over and it keeps the lift rod in one place. Then put it on one of those flat "wheeled furniture movers" and then you can easily move it around if you need to.
When I first started doing this, I considered drilling through the sub frame, but didn't think it was a good idea to compromise its integrity.
My reason for posting this now? I just did this one last night, it's been setting around in the way since I took it off this spring.
Old 06-11-2015, 10:34 PM
looks good, might have to give this a try.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 06-11-2015, 10:35 PM
I have mine up against a wall with a tarp strap going across the sub frame and the lift rod so it doesn't fall over against the wife's car. 3 years so far so good. In the winter it holds up the mower deck on end.
Old 06-11-2015, 11:36 PM
Terry C's Avatar
Terry C Terry C is offline
That's a good idea. I'm going to do it. Those blades are like a trap waiting for one of my kids to bump into it
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 06-12-2015, 12:40 AM
Berwil's Avatar
Berwil Berwil is offline
That's a great idea Mark!
Old 06-12-2015, 06:19 AM
cadzag72 cadzag72 is offline
I agree, nicely done! I also use the furniture dollies, one for the blade and 2 for the snowthrower. They also work nice for keeping spare k-series motors on!
Ian
Old 06-15-2015, 08:55 PM
j knight j knight is offline
Default Store a snow blade
I remove the back ladder support frame. Remove the hyd cylinder with the front block; that attaches to the A frame. Remove the cotter pins and drive out the rod that secures the A frame to the blade. Remove the springs and store the blade on end. Store the A frame on end also.
