Old 06-13-2015, 06:58 PM
rfk45 rfk45 is offline
Default SV725 will not start
Last week I was driving my Cub Cadet when it gradually lost power and died. I tested the battery (which was left connected in all winter) and it would not hold a charge. I got a new battery, replaced the blown fuse and all I run into is the click of the solenoid and a whine.
I have found links that say there could be an issue with a part of the starter not connecting. What I need to know is, what bolts should I use to check on the starter. I am not mechanical, and if the local shop did not have a 2-3 week delay I would hand it over to them.
I can follow instructions. This: http://www.kohlerengines.com/onlinec..._690_01_EN.pdf, only confused me...thanks in advance,
Rob
Old 06-13-2015, 07:29 PM
ganesa_9 ganesa_9 is offline
Refer to the Disassembly/Inspection and Service page of the linked manual fro the engine. If you remove the Blower Housing (typically four bolts) and expose the fan and flywheel assembly (pg 60) you can see the flywheel is a large toothed gear. The starter is a small cylinder on what might be considered the 'passenger side' of the engine and has a small gear that matches the gearing on the flywheel. When you turn the ignition the starter is elevated so its gear meshes with the flywheel gear and makes the flywheel spin. You can actually remove the blower housing and watch this happen when you start the motor. If the flywheel doesn't spin, the starter gears aren't engaging it properly or the starter isn't working. You can have somebody else turn the ignition so you can get a relatively close look at the starter. See if it lifts into position first, and if it does is it aligned so the gears mesh, and if they do mesh, does the starter turn?
Old 06-13-2015, 08:06 PM
The starter does pop up, it does engage with the spokes on the flywheel, but then it does not move it more than 1/6th of a turn and then stops.
Old 06-14-2015, 09:56 AM
The flywheel turns only a quarter, even with the spark plugs out. It is a hard stop. I am thinking I will have to take it to an expert, and wait for their queue to disappear.
Old 06-14-2015, 12:27 PM
If it won't turn with the plugs out, then it more than likely has some bad internal damage. That or something failed on the PTO. Motor is more likely the cause. Better start looking at getting a new mower. I suggest a CC older than 1995 personally.
Old 06-14-2015, 12:49 PM
Ugh, really? 3 years old, always checked/replaced the oil. What could have happened?
Old 06-14-2015, 01:24 PM
Could be lots of things, and I'm not ruling out the PTO or something in the belt drive just yet. Take the deck off of it and look up underneath. Maybe you will see something in the drive system that is bad. 3 yrs old.... maybe it's under warranty still?
Old 06-14-2015, 01:30 PM
I am going to check on the warranty tomorrow. I kept hoping that the fact that it would turn almost a quarter was a good sign. Again, not very mechanical. Then I pinned my hopes on a flywheel key, but again...not mechanical.
When I started it right after it died it made a loud sound in the engine. I shut it off quickly, but now realize that I may have made whatever is bad, worse.
Will update once someone who know what they are doing can look at it.
Old 06-14-2015, 02:24 PM
What model tractor is this?
Old 06-14-2015, 02:30 PM
Cub Cadet LTX 1050
