My good running 1541 gets no spark. Engine cranks dash lite says pto is engaged but blades don't turn. Last time I used it had to hold pto switch in engage position. Replaced pto switch still had same problem. Now I have no spark. Need help
My1541 pto lite comes on when I try to start engine. No spark. Engine cranks blades don't turn. Before this problem had to physically hold pto switch in engage to operate blades. Can anyone out there help.
I don't know what the OP's problem is but Cyclops clutches will engage with engine off/key on.
my 782, with key on, power is applied to clutch electromagnet,
running or not. ![]() |
Hello, a lot of times when you have to hold a pto switch on it's caused by a reverse switch problem. Mike
