Old 06-22-2015, 01:07 PM
Default Drive shaft pillow block bearing
Guys I'm hoping one of you can get me a pic showing how you mounted a pillow block bearing on the drive shaft of a narrow frame. When I built my 71/121 (a 71 with a Mag12) I decided to keep the deep sump oil pan. Problem is that the engine can not be moved forward to service the clutch, the engine needs to come out vertically. So in my infinite wisdom I bought a clutch, shaft and a long coupler from Mid West Super Cub. The long coupler allows me enough room to slide the complete clutch to the rear enough so that I can pull the engine. Well that part works just fine but the long coupler allows the drive shaft to run out of line and it causes a vibration. I can see the shaft running out of round. That said what I'm thinking would cure the problem is a pillow block bearing. Pic is the clutch and shaft I have. Tractor is only used for little odd jobs and plowing our garden. Power is only what a Mag12 with 500+ hours on it makes. Comments welcome.
Thanks
Old 06-22-2015, 02:29 PM
austin8214's Avatar
Is this a tall or short tunnel unit? If it's a short tunnel lots of guys add a spacer and bolt the bearind upside down to the tunnel. If it's a tall tunnel the best thing to do is, weld or bolt another cross member in the frame and mount the bearing to it.
Old 06-22-2015, 02:34 PM
Since I'm not a narrow frame guy I'll post a pic.
Old 06-22-2015, 04:15 PM
austin8214's Avatar
That's a short tunnel Sam Mac. Most pullers cut and large hole in the top of the tunnel to allow easy access to the coupler too. Then we cover it up with a piece of aluminum or stainless steel sheet metal.
Old 06-22-2015, 05:54 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
I like to put the pillow block up tight against the collar that holds the spring tension as a backup. its good to use shims so when you bolt the pillow block down you don't distort the driveline
Old 06-22-2015, 07:01 PM
Any chance one of you guys can get me a pic of how you set them up? I sure would appreciate it.
Old 06-22-2015, 07:24 PM
austin8214's Avatar
I'll try to tomorrow
Old 06-22-2015, 07:33 PM
Thank you in advance. Pretty sure I can deal with this major engineering dilemma just figured a pic of what works would confirm my thinking.
Old 06-23-2015, 10:16 AM
austin8214's Avatar
Hope you get the idea
Old 06-23-2015, 10:39 AM
That is exactly what I was looking for. Thank you very much!
