Old 06-23-2015, 10:02 PM
Big-D Big-D is offline
Default 1772 Driveshaft coupler
Finally bit the bullet and picked up a splined coupler for my 1772. I was thoroughly surprised that the dealer I stopped at had it in stock. When the salesman handed it to me I was positive it didn't have as many splines as the one on my machine. I didn't have the old one with me when I stopped. He assured me that this was the correct part. He was wrong. Mine is a 9-tooth and his is a 7-tooth. Looks like I'm returning it. Hopefully he can get me the correct part for the same price. $116, bushing included. I'm actually glad it is the wrong part. Check out the casting work on the new one. Pretty crappy how none of the holes are centered properly.
Old 06-24-2015, 07:25 AM
According to the Cub Cadet Parts Look-up site.......that part should be: CC903-1066
Old 06-24-2015, 07:39 AM
Just tossing this out for you to think about. You can convert the drive shaft to the Cyclops style CV joint drive shaft. You'll need a complete drive shaft from an 1863 or 1864, a pump adapter and the engine adapter. You would also need to drill and tap the pump shaft for a 1/4-28 bolt to hold the pump adapter onto the pump shaft.
Old 06-24-2015, 07:30 PM
Stopped back at the dealer today. They had the right one in stock. Salesman handed me the wrong part yesterday. So I'm back in business. I'd like to do an upgrade. I've tossed around a lot of ideas. How much would I have invested in a CV swap?
Old 06-24-2015, 07:37 PM
Probably around $300.00 when it's all said and done to convert to a CV shaft.
Old 06-25-2015, 07:55 AM
cub123's Avatar
cub123 cub123 is offline
X2 on the CV, that's what I did on my 1772, never thought this tractor could run so smooth
Old 06-25-2015, 10:16 PM
I'm really interested in the CV conversion, but for now I'm gonna stick with original equipment. Probably beating a dead horse. I have all the necessary means except the parts for doing the swap, but just no time. I'd like to dump the disconnect clutch upon reinstallation. I have extra flex discs and an extra coupler. Figured maybe install the coupler in place of the clutch and add 2 extra discs with longer bolts. But can't figure a way to attach the fan. I'm sure others have done this, but can't find any pics. Good idea or bad idea?
Old 07-03-2015, 12:39 PM
^^^anybody? I've searched through a lot of threads and found many people that said to dump the disconnect clutch but none state how they did it.
Old 07-03-2015, 01:05 PM
Never did one that way but my guess is that you replace the shaft with a solid shaft like the 1872 has and use that style fan and rear coupler. You'll have to figure out the length and where the hole for the pins need to go.
Old 07-03-2015, 01:13 PM
This is kinda what I am thinking. This is just a mock up. Still need an idea for the fan.
