Closed Thread
Old 06-27-2015, 10:42 AM
Default 122's engine blew
Hey guys,
I was reving up my 122 last night by the governor, I know big mistake and it started smoking out the valve cover and was running rough, then I heard a bang and it shut off and has no compression, I pulled the engine out and started stripping it down, gonna have a look inside to see what went wrong. I have a good running 10hp to repower it.
Old 06-27-2015, 10:43 AM
Engine and parts
Old 06-27-2015, 11:14 AM
Progress on assembling the new engine.
Old 06-27-2015, 01:24 PM
Yeah this engine is done.
Old 06-27-2015, 01:26 PM
Crank journal damage!
Old 06-27-2015, 01:30 PM
Nick
Sorry about your engine. The old engine maybe able to be repaired. Did it knock a hole in the block? Not sure you caused it to blow unless you buzzed it up big time.
Old 06-27-2015, 01:31 PM
Scraped block!
Old 06-27-2015, 01:32 PM
Nick
Thanks Sam, no it did not but there is a pretty bad scrape, see pic, I am putting the 10 in for now and will pick up another 12 this summer.
Old 06-27-2015, 01:38 PM
No hole, no crack = good block. Scrape = use-able.
Old 06-27-2015, 01:56 PM
I've seen worse than that. You may want to rebuild it. It would be a good learning experience for you, you'd probably have fun doing it and if done right will last for many years.
Closed Thread
