Old 06-30-2015, 03:13 PM
inspectorudy's Avatar
Default Runs fine then stalls----- HELP!
My trusty old 1811 has been a champ until lately. It cranks and runs fine for about ten to 15 minutes and starts surging and will eventually stall unless I pull the choke all the way out. Here is what I have already done. 1. drained and cleaned the tank. 2. Put on a new fuel filter. 3. removed and cleaned the carb and flushed out all of the jets. 4. Tested the fuel flow from the tank with no filter to see if it was good and it was. 5. Checked both plugs and they were clean and light grayish.6. Disconnected the fuel line from the carb to test the pump output and got just a little flow but no big pulses or squirts. Is that normal? 7. Tried the fuel line with no filter but no help.
When it starts up it idles fine and will run perfectly and then, usually on a hill or a sharp turn it will surge and then stall. I checked the float and needle and they seemed fine. I was a little puzzled by the float because it appears that it will only move up or down just a fraction before the plastic tab on the arm makes contact with the carb body. Is that right? Any ideas?
Thanks
1811 Hydro
Old 06-30-2015, 03:31 PM
FrankF3's Avatar
FrankF3 FrankF3 is offline
Thanks
Your comment on the float moving only a fraction got me thinking about my snowblower that was having a similar problem except it would seem like it was running file until you loaded it up and then it surged. On my snowblower the float needle was intermittently sticking and shutting off fuel flow when it should have been allowing it to flow.
1989 - Cub Cadet 1772
38" Lawn Sweeper #196483
60" Haban Mowing Deck #196374
Old 06-30-2015, 03:52 PM
Can anyone say if the float tab on the end of the arm should face up or down? I took the fuel pump off to check the diaphragm and it only had a little rust on the engine side of the piston. It has to little check valves that pump and suck the fuel. When I took it off they fell out and I do not know the direction that they go back in. Can anyone tell me? The diaphragm looked good with no tears in it. I also tried to run the engine with gravity only and it would not run unless I put my hand over the intake to create vacuum. Otherwise there was no fuel flow through the filter. Tomorrow I going to move the fuel tank to a higher level and try the gravity plan again. I'm narrowing it down to two possibilities and they are the fuel pump and the float/needle valve connected to it. Any other ideas?
1811 Hydro
Old 06-30-2015, 06:36 PM
Rudy, I ran my 1811 for 2 years without a fuel pump. Did you check the tank screen, fuel valve and lines?
Old 06-30-2015, 07:19 PM
timbo2's Avatar
timbo2 timbo2 is offline
Same with my 1872, ran fine gravity fed.
goodluck
- Tim
Old 06-30-2015, 07:23 PM
Billy-O's Avatar
Billy-O Billy-O is offline
Is the gas tank cap venting properly?
Plow blade
#2 Cart
QA36 snowthower
Old 06-30-2015, 11:05 PM
Thanks for the ideas. I did check the tank for debris and totally emptied it and then refilled it with new gas. If I open the bottom valve it runs out profusely. I took the gas cap out completely and it mad no difference. If I covered the carb intake then I could see gas flow into the filter but not without creating a vacuum with the carb. I am thinking it might be the float valve that is sticking but cleaned it really well. What is the down side to running it without the float in place just for a test run? What is the up/down side going to an electric pump? Thanks for the help so far. It looks like the float could go in either way and I was wondering if maybe I have it upside down. Does the smooth side go down or up? If the bumpy side is down then the little tab on the end of the arm hits the carb body when it tries to open the valve. It will open but not very much. When you guys say gravity do you mean with the tank where it is normally or do you raise it? I could not get any fuel to flow with a straight hose from the tank to the inlet on the carb.
1811 Hydro
Old 06-30-2015, 11:33 PM
cubby102's Avatar
cubby102 cubby102 is offline
If you take the float out chances are it won't run. Itll just completly flood itself with raw fuel ... the pump should put out pretty good. I havnt read everything in the thread but have you tried bypassing the fuel pump (line from tank to carb) with a full tank...see if it runs then. I'm sorry I'm not familiar with the carb you have to be much help on the specifics of it
Edit. Just read your whole post... you should have flow if the fuel level is higher then the carb...im full tank
Old 07-01-2015, 08:11 AM
Rudy, on my machine the pump went bad and flooded the crankcase with fuel. I just ran a new fuel line from the tank to the carb (with a gravity type filter) and nothing else. If you keep it above a 1/4 tank the level will be above the carb and it should flow fine. I did run a jumper hose on the failed pump from inlet to outlet because it was leaking oil. I ordered a new pump but never installed it because it ran fine. Have you looked in the Kohler manual on setting up your float to the proper specs?
Old 07-01-2015, 11:31 AM
Todd, I did run a hose from the tank to the carb and kept it under the manifold and under the carb so that it would not get above the lower part of the tank. It would not flow and I am suspecting the float/needle valve as the culprit. The thing runs beautifully while there is gas in the bowl but when I make a sharp turn or go across the hill then it starts to surge and stall. That would lead me to believe that it is the float. I do not have access to the Kohler carb settings but will look for them. Thanks for the info Todd.
1811 Hydro
