Old 07-05-2015, 11:32 AM
Justin Witt Justin Witt is offline
Default Has anyone ever tried this?
I was wondering if anyone ever tried to rewind an electric clutch for the pto on lawn mowers. I tried yesterday but must have messed up because it had continuity from the positive to the body of the clutch. Which its not supposed to. But I'm going to retry it. The wire is only a few bucks. But I was wondering if anyone has ever done this and have been successful.
Old 07-05-2015, 12:25 PM
If you want to go that way I'd try an electric motor rebuild shop. If it was me I'd replace the clutch. These guys make some nice stuff and they have good prices.
http://xclutches.ecomitize.com/
Old 07-05-2015, 01:59 PM
What wire did you use?
Old 07-05-2015, 04:16 PM
I used 24 gauge wire. Bout the same size. I thought maybe trying this first and save a buck would be good. Plus gain some experience. I found a new coil for 100 bucks on eBay. So if this doesn't work then I'll just get that. But I wanted to see if anyone has tried this.
Old 07-05-2015, 04:17 PM
Do you know that the wire used in coils has a special coating on it so that it doesn't short against itself? You can't just use any ol' wire.
Old 07-05-2015, 05:27 PM
Justin
Just a FYI I asked the local motor shop about re-winding the field coil for a PTO and the price was more than a new PTO. As Jon said the wire has a special coating on it. You would need the same size, type and length of wire to make it work properly. I'm not saying don't give it a shot just trying to give you some more info. If you decide to give it a try I will try to help as far as info is concerned. I used to have some contacts in the electric motor re-building industry back when I was in the quarry business.
Old 07-05-2015, 05:29 PM
generally re winding is more expensive due to needing special wire and the time involved, i have a friend that works in a shop rebuilding locomotive traction engines and we've discussed this topic a few times.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 07-05-2015, 05:54 PM
The wire is just enameled wire. Pick it up at menards for 2 bucks per 100 ft.
Old 07-05-2015, 06:39 PM
Well, there's your problem. Menards sells copper for rewinding motors?
What was the resistance of the newly wound coil?
Old 07-05-2015, 06:45 PM
I have no idea. Never checked it. Only the continuity. It will probably be fairly "high" in relative terms wouldn't it.
