Old 04-22-2010, 06:17 AM
IHinIN IHinIN is offline
Default My newest attachment, carry-all
I built a carry-all that attaches to my sleeve hitch. I added hinges and a handle to it so it can be dumped from the seat of the tractor. It comes in very handy for hauling grass clippings and sticks to the burn pile. I had about 200 lbs of sandbags in it the other day and it worked fine for that but the front of the tractor was extremely light. I also welded a piece of pipe to my homemade spring assist as a holder for a 3/4" wrench to adjust the anti-sway bolts on my sleeve hitch as well as the down stop on the lift handle.
Old 04-22-2010, 07:47 AM
Nice fabrication work IHinIN, That's a beefy looking sleeve hitch and lower bracket you made. Looks great
Old 04-22-2010, 09:48 AM
Looks great!
Old 04-22-2010, 12:46 PM
Excellent job, IHinIN! Your carry-all looks great.
Old 04-22-2010, 02:57 PM
gazoriginal gazoriginal is offline
looks good, and gives me some ideas!. do you have the dimensions for the front of that- where it attaches to your sleeve hitch adapter.
Old 04-22-2010, 05:06 PM
The hitch piece is a 4.50" long piece of 4" x .25" wall tubing cut lengthwise about 3" wide with a 5/8" hole for the pin. There's a piece of 1/4" plate welded to it that extends down to the bottom of the 1.50" x 2" tubing. There are 2 gussets welded between the 1/4" plate and the bottom of the hitch piece.
Old 04-22-2010, 07:14 PM
thanks
Old 04-22-2010, 08:46 PM
I checked and the hitch piece is 2.50" wide, not 3".
Old 04-26-2010, 08:39 PM
Here's a couple close-up pics of the hitch.
Old 04-27-2010, 04:02 PM
Jeff122's Avatar
Jeff122 Jeff122 is offline
Great idea! Nice job.
