Old 07-05-2015, 09:53 PM
FrankF3's Avatar
FrankF3 FrankF3 is offline
Default Painting Options?
The brown truck is finally scheduled to arrive tomorrow with my order from XTREME Motorworks. What painting options/technologies would give the best adhesion without having problems of peeling, give a good finish without going exotic. I am just looking for plain old black. What have you guys had the best luck with? Primer, no primer, an initial etching of the parts? Rustoleum, rustoleum red primer?
1989 - Cub Cadet 1772
38" Lawn Sweeper #196483
60" Haban Mowing Deck #196374
Old 07-05-2015, 10:10 PM
bocephus1991's Avatar
I'd use epoxy primer, then acrylic enamel paint. Shot it with a hvlp paint gun. If you don't have any experience or access to the equipment you could rattle can it. Or take it to a body shop and have them paint it. That's my 2cts. What are you painting exactly?
Brian
Old 07-05-2015, 10:19 PM
you dont mention what your painting so i will assume its steel. start by scuffing it with a red scotch brite pad and then wipe it with degreaser( brake cleaner also works good) spray it with epoxy primer and then top coat with your color of choice. when it come to spray paint ive had good luck with rustoleum epoxy and paint.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 07-05-2015, 10:43 PM
john hall's Avatar
If you want durable, Rust-Oleum industrial enamel, Lowes carries it in black and white around $6 a spray can. I made and painted a handrail for my dads house 3-4 years ago. No signs of chipping or rust, handrail is completely outside. I can't remember if I primed it, if so it would have been with a spray can, nothing fancy. It's the best results I've ever gotten from a spray can.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 07-06-2015, 08:33 AM
FrankF3's Avatar
I have 3 sets of torque arms, 1 for the 1772, 1 for the 1572 and 1 for the 1872 and a 3-PT Cat 0 hitch for the 1772. From what Aaron told me,all items are shipped as bare steel.
Old 07-06-2015, 05:21 PM
FrankF3's Avatar
Sam, do you happen to have the length dimension of the SGT torquearm. I pulled mine of of the shipping box and it seems very small and was wondering if I have the GT torque arms instead.
Old 07-06-2015, 05:52 PM
Post a pic and I can tell you. This pic is the SGT brace.
Old 07-08-2015, 09:57 PM
FrankF3's Avatar
Sam, I finally got some free time to take a picture. Maybe these are the correct ones. Let me know what you think.
