Old 07-06-2015, 04:42 PM
Nightow1 Nightow1 is offline
Default Starter issues
Ok my KT17 series II, the starter is having problems. It will lock up sometimes, and i noticed some sparkes from the ring. Is there some sort of adjustment when installing the starter. It makes a heck of a noise when engaging. I just dont want to replace something that just needs adjusting.
Old 07-06-2015, 06:18 PM
BTDT before...........Bite the bullet and replace it. There is NO adjustments.
Old 07-07-2015, 11:45 AM
It was new then I restored the tractor, rebuilt the engine installed the starter and this problem started, Did i screw something up. I can't imagine it went bad sitting on my shelf.
Old 07-07-2015, 11:51 AM
You made no mention of this in your first post.
Perhaps seeing if there is a warranty on it, so you can get it replaced.
Old 07-07-2015, 01:37 PM
No its been almost 2 years since i bought it. Used it around 6 months then it sat until this past month
It works and starts, just make a lot more noise than it use to and looking in undrt the shield you can see sparks when you engage it.
Old 07-07-2015, 01:52 PM
It is a DC Motor. Inside that motor, there are a set of brushes. Those brushes come in contact with the armature. When revolving, there is sparking. This is normal.
Old 07-07-2015, 02:34 PM
I know that, i have rebuilt many starters, as I said it's sparking from the flywheel starter wheel.
Old 07-07-2015, 02:46 PM
Loosen the starter, reseat it and tighten.
Short of that working, you might have to do a visual inspection while the starter drive is engaging.
Old 07-07-2015, 03:05 PM
Berwil's Avatar
Berwil Berwil is offline
Maybe lower mounting ear broke off and it's not holding the starter tight enough to the flywheel and is causing grinding gears and sparks? Broken tab happened to Todd (zippy). He took it to a fabricator/machinist to have it repaired, perhaps you know of a good one?
http://www.onlycubcadets.net/forum/s...arter+mounting
Bill
Old 07-07-2015, 03:58 PM
Tab is good, so ill loosen it up and re-install it see if that works.
