Old 07-09-2015, 10:26 PM
Justin Witt Justin Witt is offline
Default Straightening a shaft on a starter
Is there any easy way to straighten a shaft on an engine starter? Has anyone tried to do it? I don't want to break/damage the shaft, windings, or commutator, anyone have any ideas?
Old 07-09-2015, 10:41 PM
Just bite the bullet.......and replace the whole starter.
Old 07-09-2015, 10:43 PM
Can't....its on a techy and they want a lot more money for one then I would want to put in one.....
I'm sure in the bending process that the commutator bars and windings will be damaged, so yes, replace the whole starter.
Old 07-09-2015, 11:23 PM
cubby102's Avatar
cubby102 cubby102 is offline
Sad to say but replacement is the way to go... you could try putting the bent tip in a bench vice and pulling on it but chances are it will never be perfectly straight again and a good chance of windings getting broken.... ebay has had some good prices on techumseh starters...
Old 07-10-2015, 12:47 AM
Getting divorced cost a lot more than I wanted to put into it too, but I couldn't just let her set there in the way forever.
Old 07-10-2015, 06:15 AM
Leadslingingdaddy's Avatar
When did CC put "Techies" in their mowers?
Old 07-10-2015, 07:48 AM
Depends on where it is bent.
If it is like a delco old skool starter, you can chuck it in a lathe on the laminated part and indicate it, then use the cross slide to put pressure on the high side of the shaft and re indicate till it is true.
I'm thinking the armature is rubbing the field shoes?
Or you can chuck the bent part of the shaft and push on the laminations.
Usually they bend the shaft where it enters the laminations.
take your time and think it out.
You have nothing to loose as it unusable as is.
If you have a collet chuck, use it and put the shaft in the appropriate size collet, as you will not dent the shaft with the 3 jaws of chuck as the shaft is soft.
it is do-able, if you have some equipment.
if all else fails, possibly you can find a good used one on evil bay.
Old 07-10-2015, 08:26 AM
http://www.ebay.com/sch/i.html?_from...arter&_sacat=0
50.00 is a rough SWAG since you failed to give enough information about the item in the first place.....Time is money.. All else fails....Repower....
Old 07-10-2015, 10:18 AM
cubs-n-bxrs's Avatar
Inquiring minds want to know how the heck a starter shaft gets bent.
