Old 07-30-2015, 10:32 PM
rwairforce rwairforce is offline
Default v61 Tires
Just wanted to share my good fortune today.
I received both sets of my V61 tires from Miller Tire, with tubes of course.
They look just as great as all those I've seen on other members tractors.
I hesitated a little because at nearly $75 a tire with tube and shipping but in the end I talked myself into getting them. I figure they'll probably be the last front tires I'll ever need for the two tractors that are getting them.
See picture. Don't they look awesome? Even if they haven't been mounted yet.
Why do they require a tube? Just wondering.
Randy
Cubs: 71, 72, 127, 149, 1440, 2186 and 1864
John Deere 110 round fender
John Deere 140 H3
Sears: GTV16
Old 07-30-2015, 11:39 PM
Congrats on the tires Randy
What they going on?
Old 07-31-2015, 05:09 AM
Billy-O's Avatar
Billy-O Billy-O is offline
What they going on?
Rims!?!
Plow blade
#2 Cart
QA36 snowthower
Old 07-31-2015, 05:14 AM
sbauerz28's Avatar
Why are you running a tube?? I thought they were tubeless. I never put tubes in mine.
Old 07-31-2015, 08:30 AM
Same here, I didn't use tubes in the set I had.
Old 07-31-2015, 09:00 AM
jimbob200521's Avatar
A bit dirty after some wet grass mowing earlier this year but no tubes here either
-Ryan
Old 07-31-2015, 10:47 PM
CAO65 CAO65 is offline
It's my understanding these tires are sized in metric as opposed to standard. Therefore, the sizes sold may have some size variances with the standard sized rims which may cause tires to loose air pressure. So, using tubes would eliminate this problem. I'm planning to put these tires on my GT 2000 in the fall. They looked awesome.
Old 07-31-2015, 11:05 PM
Originally Posted by Billy-O View Post
Rims!?!
Well I guess I rolled right into that one.
Old 08-01-2015, 09:45 PM
Tubes?
Only because the Miller website indicated that tubes are needed.
I sure would have saved the $50 I spent for four tubes if I knew I didn't need them.
I'm putting them on my 1440 and 1864 I think. I was going with both 1440s but the 1864 does most of the work.
I just got two of them mounted tonight. I really don't enjoy wrestling those things on by hand but I got both on.
How many pounds of air do you guys run in them. I usually put 15lbs in my fronts. Thanks.
Randy
John Deere 140 H3
Sears: GTV16
Old 08-01-2015, 10:04 PM
I thought I would go to Miller Tire to check it out again and it does indicate that these tires are tube-type tires and require a tube. Real nice blue letters too. I added the link just for your information. I really like the tire and I suppose it doesn't hurt having a tube, just $50 lighter in my pocket.
http://www.millertire.com/products/i...70-60-8-6-ply/
Randy
John Deere 140 H3
Sears: GTV16
