Old 08-06-2015, 08:21 PM
GT5881 GT5881 is offline
Default 3 pin driver plate
Hello everyone,
Can my 3 pin driver plate be repaired ? I already changed the motor mounts to solid ones from JeffinPA, previous owner used lug nuts.
Old 08-06-2015, 08:48 PM
if you put in solid mounts you no longer need that flex driver, you can install a solid driver from an older tractor which is far cheaper. i have a few for sale, pm me if interested.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 08-08-2015, 06:15 PM
tpelle tpelle is offline
GT5881, that's the way to go. Use the solid driver plate.
See my thread
http://www.onlycubcadets.net/forum/s...ad.php?t=40044
for some detailed pics of what I did to my 1000.
Old 08-13-2015, 02:36 PM
Hey everyone ,
I'm still waiting for parts to arrive.My latest finding yesterday was a cracked spiral pin, now I need to order a spiral pin.it's coming together slowly.
Old 08-13-2015, 07:40 PM
twoton twoton is offline
So hey GT5881, what did you end up doing re: the 3 pin driver? I've been thinking about going to a solid 6 pin driver but not sure about where to get one. I know MWSC sells them. Anybody know of any place else?
Old 08-13-2015, 09:29 PM
member Yosemite Sam makes them also.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 08-13-2015, 10:03 PM
Thank you for the plug, but I don't have any on the shelf right now and with my current work-load I might not be able to get one turned out very quick.
Old 08-14-2015, 09:37 AM
mickb72 mickb72 is offline
Default cub
Check out Zach Kerber mach. Mike
Old 08-14-2015, 07:27 PM
https://zkbrmachine.com/item.php?product_id=80
Old 08-16-2015, 01:12 AM
Hello Everyone,
Cub cadet 1200 is all back together as of yesterday. purchased solid mounts from jeffinPa and purchased used solid 3 pin driver plate from olds45512.
Drove around for couple of hours trimming branches,
