Old 08-07-2015, 02:28 PM
swacor swacor is offline
Default M18 engine
Hi guys, i wanted to know if any of you could tell me if this engine would be a drop in on my 1872.
Old 08-07-2015, 02:54 PM
What is the Kohler "spec" number...???
Old 08-07-2015, 05:26 PM
I'd say probably. As Roland posted with the spec # he could say yes or no. That said if the shaft size and length are the same I'd guess you will probably need to swap some of the accessories from your old engine to the new engine to make it play.
Old 08-07-2015, 09:26 PM
Model # M18QS. Spec # I believe is 24646.
Old 08-07-2015, 10:04 PM
I believe is 24646
Isn't in on that tag pictured....???
Old 08-07-2015, 10:18 PM
It could be 24696. I'm also looking at a picture of this engine that I'm sharing with you guys so I'm not 100% on the spec# but that's what I see.
Old 08-07-2015, 10:50 PM
GTKid GTKid is offline
This is simply an observation, but the air cleaner housing looks like the ones on Magnum powered gravelys. I'm only familiar with the Cubs using the regular old circular filters
Only a 1282 with ~700 hrs(serial 729357)...
Just red and black and ain't goin back!
Old 08-07-2015, 11:45 PM
RR1862CC's Avatar
RR1862CC RR1862CC is offline
Not sure about a super but my 1862 had that air cleaner on it when I bought it and it rubbed the firewall. It had a non-original engine in it so I had to get an air cleaner from a cub to fit correctly.
Allis Chalmers 416
Massey Ferguson MF-8
Brinly 10"plow
Old 08-08-2015, 06:25 AM
Sorry, I misunderstood. I thought you had the engine already.
The 24646 IS a Cub Cadet specified engine. With the exception of that Air Cleaner, it should drop into a Cub Cadet without much problem(s).
The 24696 was made for Melroe/Bobcat.
The area of concern is the "crankshaft" in order for the Elec PTO to mount and operate correctly. Here is the data on these engines.
24646 has crankshaft 52-014-66S = 1.125" x 2.80"
24696 has crankshaft 52-014-65S = 1.125" x 2.58" (thus being about 1/4" shorter than the Cub Cadet crankshaft)
Old 08-08-2015, 10:08 AM
Well my dad and I told the guy we would take it. The motor is new still in the Kohler box. I thought for a little under $1,000 it would be worth it. Hopefully it works out.
