Old 08-11-2015, 12:49 PM
Shaner Shaner is offline
Default Rear PTO wiring question
hello, i just got a rear PTO, tiller and brush hog all in one swoop.
ive been reading up on the rear PTO wiring and im kind of confused as to how this works. i looked under the hood of my 2072, and i found a pig tail that has a jumper wire in it. does that jumper wire come out, and the pig tail go into a switch? i do remember when i had the fenders off finding a pig tail wire by the light wires that i know goes to the PTO itself on the transmission.
can anyone help me figure this out? im kind of confused on what kind of switch to use. some say use a PTO switch like the one for the front but some say directional switch not a PTO switch. kinda confusing!
thank you in advanced.
Cubs: 2072 w/60" Haban, 782 w/Johnson 14 loader & 44" deck, & 169.
Others: Ford 120, Ford LGT100, Ford LGT125, 2 - Ford LGT145s, & 4 - John Deere 140, H1 and H3.
Old 08-11-2015, 12:59 PM
Well, I can certainly help you out. This, in my world, is not a big deal.
I will go and look at the Wiring Diagram to see if the Factory provided for a Rear PTO wiring or if it has to be custom fabricated.
Old 08-11-2015, 01:13 PM
FrankF3's Avatar
FrankF3 FrankF3 is offline
The jumper wire comes out and is replaced with a short harness that connects to a switch that is installed in an existing hole on the metal part of the instrument panel support near the headlight switch or ignition switch, depending on the model. In one position of the switch, the front PTO is activated (I think the switch is up) and in the other position (down) the rear PTO will be activated. this switch does not activate the PTO, but merely switched which PTO is turned on when the main PTO on-off switch on the dash is turned on.
1989 - Cub Cadet 1772
38" Lawn Sweeper #196483
60" Haban Mowing Deck #196374
Old 08-11-2015, 01:24 PM
Here ya go.........
Old 08-12-2015, 11:02 AM
okay i think i understand. does anyone have a part number for the correct switch i need to use? would just a two pronged two positioned switch work okay for this? thank you guys for you're help. one step closer to getting my PTO working.
Old 08-12-2015, 11:08 AM
Look at the LH image in the diagram I posted for the Cub Cadet Part #.
You can also pick up a SPDT Switch - 10A rated or more, from a local source.
Old 08-12-2015, 11:48 AM
Leadslingingdaddy's Avatar
I just wired a dedicated switch for the rear pto on my Super.
Old 08-12-2015, 08:17 PM
My pto "switch"
Old 08-15-2015, 01:11 AM
doh i missed that. i just checked on the part number....of course its NLA. i might just wire in my own switch....you said i can pick up a SPDT switch...dont mind my ignorance but what does SPDT mean?
Old 08-15-2015, 09:06 AM
don't mind my ignorance but what does SPDT mean?
SPDT = Single Pole - Double Throw
