Is this the correct hanger for a model 71 38" deck? If not, will a model 123 deck hanger work on a model 71 38" deck?
The one you have is for a wide frame so no it won't work, the one off the 123 will be correct.
So this is my 38" deck and I assume the eyelet bolt hangers in front aren't original parts?
That's a pin on style deck so yes those are correct, is the undercarriage off the 123 for a pin on deck or is it quick release?
I will look, but I think the two keeper things towards the back of the 123 deck hanger have springs like a quick release? Ok here is my 42" deck. Also how much for a new idler pulley and spring? Thanks |
The 42" is a little much for the 71,stick with the 38"
Your mule drive should look like this one for it.
Up to 534 and counting... I give up updating my profile! |
I agree on the 38 inch deck for the 71. Looks like I'm gonna have to get some of those deck hanger things like on my 42 inch deck, towards the front for my 38 inch deck. |
If you have a mule drive and lift frame for/from a 1X2/3 it should work with the cast end deck (in your picture) on your 71 just fine without modification to the deck or to the mule drive/lift frame. The eye bolts on the 38" deck in your picture are factory equipment.
