Old 08-16-2015, 01:35 PM
Rmowl's Avatar
Rmowl Rmowl is offline
Default No spark issue solved
Hi, after some searching old threads on here I found the issue to the no spark problem on my 102. I put on a carter carb that I cleaned up, ran nicely, then wouldn't fire after the first run. Had voltage going in and out of the coil. Researched and found that I didn't have the points gapped correctly. Got them opened at the widest point and they were way too wide. Not sure why it would fire up before and stop all of a sudden, but it fires up better than ever now. Thanks!
-Rick
IH 782
IH 126
CCC 1863
Old 08-16-2015, 01:37 PM
Did you time it? Or just gap them....??
Old 08-16-2015, 03:18 PM
Rmowl's Avatar
Ha, that's the first thing my buddy asked when I told him I got it going. Came over and hung out and timed it for me showing how, and surprisingly it was dead nuts. Lesson learned!
-Rick
IH 782
IH 126
CCC 1863
Old 08-16-2015, 03:28 PM
johns cubs's Avatar
johns cubs johns cubs is offline
Hey Jon, just seen your post about timing. Never thought about it befor so for the hell of it i popped my points cover off of my running k301 and checked them. Was out of time and gap was atleast.040. My question is how was it running that far out of whack and what would happen if i would have not adjusted? It seems to start easier but runs the same.
John
