Old 08-16-2015, 06:12 PM
Mr Bob's Avatar
Mr Bob Mr Bob is offline
Default Rattle Can Yellow for Cub 149
I am re-doing my Cub 149 and used Magic rattle can Cub Yellow from Tractor Supply on my frame. I absolutely will not use it again. Paint is too soft and takes forever to dry. I bought a can of rust-oleum Gloss Marigold and sprayed my Hydro Pump and Cylinder with it. Went on well and dried fast. Pretty sure it will be a hard finish. Looked a little lighter in color than the Magic paint. Has any one used it on their Tractor? Also saw a Rust-oleum Yellow Eq. Catipaller rattle can spray paint. Any one used this and if so, how does it compare color wise to the Cub Yellow spray can from a Cub Cadet dealer? Sorry for the long post and thanks in advance for your help. Have a great day.
Bob
Old 08-17-2015, 05:52 AM
IHCadetCollector's Avatar
IHCadetCollector IHCadetCollector is offline
I know where you are coming from with the majic brand paint.
In addition, I have found that Rust-Oleum paints are pretty good. However as J-Mech said, Cub Cadet paint is guaranteed to match. I use paint from the Case IH dealer. It's high quality stuff made by Valspar. I buy it buy the gallon and keep a couple spray cans of each color for touch-ups.
I lost track of what I own a long time ago!
Old 08-17-2015, 09:48 AM
Mr Bob's Avatar
Default Rattle Can Yellow Paint
Thanks for the reply's. At $17.00 a can at my local Cub Dealer, Just can't afford it. I am doing a make over and not a restore as everything will not be as it came from the Factory. I envy those that can do a total restore. Beautiful Tractors.
Have a great day.
Bob
Old 08-17-2015, 11:08 AM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
http://www.amazon.com/gp/aw/d/B00EFFX7DS?vs=1
Not sure if this matches the old yeller or new? But a good deal on good paint.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 08-17-2015, 12:32 PM
dgrapes59 dgrapes59 is offline
For what it's worth... In my area I have found spray paint at the Cub CADET dealers is in that $17 range, but at the IH dealers it is around $10...
Good luck,
David
Old 08-17-2015, 12:49 PM
j4c11's Avatar
j4c11 j4c11 is offline
The Valspar paint takes A LONG TIME to dry. Weeks,3-4. I did a 46" deck using the IH white. Great paint though, excellent coverage, doesn't run, and once dried it seems like it will take some abuse.
Old 08-17-2015, 07:58 PM
This is the Hot Set Up.
http://www.lowes.com/pd_636356-678-O...=50404976&pl=1
Cheap and dry's fast, just take a chip and they will match the color. Don't need no stinkin gun, a brush or roller and your good to go.
Old 08-18-2015, 11:43 AM
Mr Bob's Avatar
Sam Mac,
I would never use a brush or roller on my tractor. I'm from Wv. but I have my limits. Don't know if you are joking or not but no problem either way. Have a great day.
Bob
Old 08-18-2015, 08:42 PM
Originally Posted by Mr Bob View Post
Sam Mac,
Bob
Bob
I was just goofing. I tend to have a twisted sense of humor. If it's after 5:00PM all bets are off. :bigth ink:
Old 08-18-2015, 09:56 PM
Brushes and rollers are for detailed work, a mop is what real men use to paint things!
