Old 08-17-2015, 10:55 AM
Jbo_c Jbo_c is offline
Default Add implement lift to 782
How hard/pricey would it be to find the parts to add a rear sleeve hitch to a 782?
Found one priced pretty good but no lift, which I want/need. Trying to decide if its worth the hassle/expwnse of buying it and adding the lift.
Would be all internet shopping. No support to speak of locally and nothing in the way of fan base here either that I've found.
Thanks.
Jbo
Old 08-17-2015, 11:20 AM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
You should be able to get everything for $100-200. It's not hard to install at all. Check the sponsors at the top of the page. The pricey part comes when you start buying implements
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 08-17-2015, 12:24 PM
Including the rock shaft and sleeve? Or were those standard?
Thanks.
Jbo
Old 08-17-2015, 04:37 PM
inspectorudy's Avatar
I have an 1811 which is almost the same as your tractor and I would say $200-$300 minimum. Just the sleeve hitch and parts for it are usually over a hundred dollars. The necessary parts are the actuator arm that bolts to the rear end, the frankestien bolts, the rear end bracket, the lift rod, the two lift pieces for the hitch and then you will need the long rod that goes from the ram to the rear of the tractor and the little attachment bracket that goes with it. I bought mine from ebay and the guy sold me the wrong one but one of our forum members need it so it worked out. Be careful because people will sell you stuff that you cannot use. If you can find the exact dimensions of the long rod and the angle in it it will save you some time. If were you I would buy the whole kit from one of our sponsors and you will be way ahead.
BTW, I live in Tyrone GA and if you are anywhere near I would be glad to show you all of the pieces.
1811 Hydro
Old 08-17-2015, 04:57 PM
j4c11's Avatar
j4c11 j4c11 is offline
Once you get the lift, sponsor Mark Hellrung (link at the top of the page in the sponsor section) makes one heck of a sleeve hitch.
Old 08-17-2015, 05:21 PM
efharg's Avatar
efharg efharg is offline
Extreme motorworks makes a nice 3 point lift for the 82 series. They also make sleeve hitches.
http://www.xtrememotorworks.com/
882
Old 08-17-2015, 05:50 PM
Thanks for the offer, inspector. I live diagonally across Atlanta in Gainesville, so would have to work out just right for me to drop down. Maybe if I were just passing through . . .
I was thinking $300 or so would probably be about what it would take to do this. Don't think that's worth it. Guess I'll just keep waiting for something that already has a lift on it.
I've been patient, but I'm getting less so. There just isn't much market for these around here apparently. Didn't take an opportunity on a manual lift a couple of weeks ago and have regretted it since. Should have bought it to have one to use in the garden until I can find one with a hydro lift.
Thanks.
Jbo
Old 08-17-2015, 08:34 PM
If you make use of the hitch you will be more than happy with the cost. Here are some of the uses I have gotten from mine.
1811 Hydro
