Old 08-20-2015, 09:23 PM
dfd238 dfd238 is offline
Exclamation PTO not engaging
I have a CC 1541 where recently, the PTO will not engage after I have mowed for a short amount of time. It doesn't turn off on its own, just won't re-engage if I stop it. The next day, it works again and the process is repeated. I'm pretty sure the clutch is the problem, but I have limited experience fixing these things. How to I check to see if the PTO clutch possibly went bad?
Old 08-20-2015, 11:22 PM
My first guess would be field coil. My 782 did the same as you've described.
Old 08-21-2015, 08:46 AM
Welcome to OCC. Have you checked the air gap of the clutch? Pretty easy job, just download the manual for your tractor and it will walk you through it. Good luck and let us know how it goes.
Old 08-21-2015, 12:41 PM
USMC_SGT USMC_SGT is offline
Check the electrical connections as well, had a similar issue with my 2182, it was just a bad connection within the junk connector.
Jon
Old 08-23-2015, 03:45 PM
I adjusted the gap to .017 according to manufacturer specs, no luck there. So I took the clutch apart and found that the field is no longer operating. Now ordering a new/used field and will let you know how it goes. Thanks for the input.
Tags
1541, clutch, gaps, pto
