Old 08-22-2015, 10:55 AM
jchristensen jchristensen is offline
Default Kohler K341 camshaft
Anyone know for sure if the K341 camshaft is the same as the 10, 12, and 14 horsepower engines?
Old 08-22-2015, 11:01 AM
timbo2's Avatar
timbo2 timbo2 is offline
looks like it.
Just go here and plug in different tractors with the various engines and it will show.
http://www.partstree.com/parts/cub-c...arden-tractor/
- Tim
Old 08-22-2015, 11:09 AM
cubs-n-bxrs's Avatar
Was just at parts tree .com myself and the 12-16hp engines have the same cam pt# listed. Didn't look at the 10s but would imagine the same pt# as well
Old 08-22-2015, 11:26 AM
Merk Merk is offline
10 thru 16 hp use the same cam.
Project Uncle Dick
Cub Cadet 70
Old 08-22-2015, 01:09 PM
Correct.
But there are at least 3 different camshafts.
Old 08-22-2015, 04:32 PM
Correct.
The early 10 hp had a non compression release 2 piece cam.
Second one is the compression release used in late 100s thru 1650.
Third one-generators?????
Keep in mind I only deal with garden tractor engines.
Project Uncle Dick
Cub Cadet 70
Old 08-22-2015, 05:47 PM
Your correct Dale. I didn't even think about the early two piece cam. I was thinking of the three "color codes". Red, white and green. I don't off the top of my head remember which is which, but they are different. IIRC, two will work fine (red and green) but there is an issue with the white one. I think it killed torque. Where's Don, he knows....
Old 08-22-2015, 07:36 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
red was L&G , green was a industrial , red/white was the K361
Old 08-22-2015, 08:45 PM
So..... will all 3 work? Or is one a power killer? Maybe it was a power maker? You told me before Don, but I don't remember.
Old 08-23-2015, 08:45 PM
Thanks for all the good info. If they are the same, then I have one out of a k301 I could use if I needed.
The situation of my missing cam has changed. I had sent mine off to Brian Miller in May and as of July 5 I had lost contact with him and was getting worried. So I started this conversation and others on various forums to make an alternative plan.
As luck would have it, he contacted me on Saturday and all is well and he will be sending my parts on Monday.
Thanks for all the good feedback and I will keep this info in my mind for future projects.
Tags
camshaft, k341, kohler
