Old 08-25-2015, 04:18 PM
BIG RUH BIG RUH is offline
Default Decal removal
What is the best way to remove the old decals and adhesive from the side panels on an 1862?
Old 08-25-2015, 04:23 PM
Heat gun to get the decals off and rubbing alcohal to remove the adhesive, its a slow process but it won't damage the paint.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 08-25-2015, 04:26 PM
RR1862CC's Avatar
RR1862CC RR1862CC is offline
Until I bought a remover tool I used a heat gun or hair dryer then cleaned it up with Glue remover or lacquer thinner. This is on metal bodies not plastic. I would think the same would work on the plastic but not use too much heat.
Allis Chalmers 416
Massey Ferguson MF-8
Brinly 10"plow
Old 08-25-2015, 05:01 PM
me too....
Old 08-25-2015, 05:22 PM
RR1862CC's Avatar
The glue remover we used was a 3m product sold at NAPA. We now use a slow speed pneumatic grinder that uses a rubber wheel to take them off. Best tool ever! NAPA sells the same type wheels to use in a drill but you have to use a slow speed.
Allis Chalmers 416
Brinly 10"plow
Old 08-25-2015, 05:41 PM
I use a heat gun and prep-sol
Old 08-26-2015, 12:49 AM
bocephus1991's Avatar
You could try wd-40, not good for much else! Lol
Brian
Old 08-26-2015, 06:43 AM
nkeel8106's Avatar
nkeel8106 nkeel8106 is offline
I took the decals off the hood of my 1864 due to them peeling off somewhat on their own. I used a mixture of vegetable oil and baking soda, simply mix them together in a jar and it becomes a paste. Rub the paste on the adhesive and allow to sit overnight. Worked well, you may have to apply more than once and it didn't seem to harm the plastic.
Nathan
Gardners, PA
Cub Cadet Yanmar SC2400
Old 08-26-2015, 07:03 AM
Tankman's Avatar
Tankman Tankman is offline
Heat gun and Goop glue remover.
Tankman
'95 CCC 1641
Eastern PA
USMC
Old 08-26-2015, 10:10 PM
inspectorudy's Avatar
Just removed a brand new decal from a JD 318 because I was too lazy to go and get a little dishwasher soap when I put it on. Glue stuck like crazy but hot air heat gun and a little patience did the trick. I then used a little paint thinner and the glue came right off.
1811 Hydro
