Old 08-27-2015, 08:03 AM
sawdustdad's Avatar
Default Trailering Cubs w/o damage?
After a few attempts to move some of my restored cubs on my flatbed trailer, I still struggle with the best tie-down technique. I usually use wide nylon strap ratchet tie-downs, but always wonder where to best place them on the tractors to avoid damaging the paint, bending the sheet metal, etc. Right now I am running the straps over the foot pads and under the frame, from side to side.
I've recently thought that a single turnbuckle under each tractor, that pulled the tractor straight down to the bed of the trailer would be ideal.
How do you guys transport your cubs to shows, etc, w/o damaging them?
Old 08-27-2015, 08:10 AM
johns cubs's Avatar
johns cubs johns cubs is offline
I have a buddy that cuts strips of cardboard to put between straps and paint, usually over the tunnel.
John
Old 08-27-2015, 08:57 AM
mudpatrol1's Avatar
mudpatrol1 mudpatrol1 is offline
in the auto transport business i used axle straps made from nylon,or basket straps that covered the tires and were secured to the truck with d rings welded midway up the bed. i have hauled anything from a model a to a $500,000 dollar porsche,so being careful is the key. you might try looking at AW Direct to see what kind of straps they offer,maybe even motorcycle tie downs would work.
Old 08-27-2015, 09:38 AM
ford4150's Avatar
ford4150 ford4150 is offline
Old 08-27-2015, 10:19 AM
Berwil's Avatar
Berwil Berwil is offline
It's been my experience that you want to pull forward and backward at the same time. Or be up against the front bulkhead and pull the tractor tight against it. You can use these motorcycle straps to wrap around the front and rear axle to avoid damage, then hook a regular ratchet strap to them to the trailer. One on each corner pulling out and away would lock it down.
It's only a cub, so I'm sure one in the front and one in the back with a strap across the trailer through the loops would be sufficient. Just remember to orient the strap so it is pulling front and back (like a banana shape), if you just go straight across, the tractor will roll front/back.
http://www.amazon.com/gp/aw/d/B00D8F...2xL&ref=plSrch
Bill
Old 08-27-2015, 10:28 AM
I use heavy duty MC tie downs. 2 on the front and 2 on the back.
Old 08-27-2015, 10:46 AM
I have a clevis I put in the tow hitch to run the strap through and use 2 straps around the front axle. I'd rather mark the paint a little bit than have it come loose and fall of the trailer because I was more concerned about the paint than having it anchored good.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 08-27-2015, 03:58 PM
cubby102's Avatar
cubby102 cubby102 is offline
Had d hoops in the floor of of my old enclosed and ran straps over the tires
Old 08-27-2015, 05:33 PM
I've got 4 700 LB ratchet straps that I use on 4 corners of the tractor. Two on the rear axle, and two on the front, pulling in opposite somewhat lateral direction. I also put a cam buckle strap over the seat to keep it from flapping (just cuz I had one.) More tie downs are better than less IMO.
Old 08-27-2015, 10:48 PM
I use coated steel cables and padlocks. It kind of depends on your trailer, because I can loop them around tubular railing and secure them down, so someone who doesn't have that feature may not be able to utilize the same materials as I do......or what someone else does.
