Old 04-26-2010, 11:44 AM
cledford cledford is offline
Default Marvel Mystery Oil & 1450 – run in gas, or also use as oil?
I’ve seen a lot of post recommending the Marvel Mystery Oil for reducing carbon build up. I’m wondering if you guys run it as a gas additive (only) or also use it as a engine lubricant, replacing normal oil as well? (As the Marvel container states it can be used…)
Thanks,
-Calvin
Old 04-26-2010, 05:53 PM
CBH's Avatar
CBH CBH is offline
Use it everywhere that you can...as directed. It's good stuff!!
Old 04-26-2010, 06:08 PM
Amigatec's Avatar
Amigatec Amigatec is offline
Would this help with backfire?
Almost everytime I shut the 129 off it will backfire.
Pat Benner Haskell OK
Old 04-26-2010, 06:14 PM
bridgewatertek's Avatar
bridgewatertek bridgewatertek is offline
Use it along with oil, not to replace it as MMO is too thin.
Jim Bridgewater, KD0FJO Osage, IA
1976 IH Cub Cadet 1650, 44A rotary mower deck, 42" snow blade, QA42A snow thrower, rear blade, cab
Well, that's out of date. Current count is 2 LT1050's, a 76, 1 2284, 1 2130, 1 2135, 1020, and 10 1250- 1650's, with decks, blades, snow throwers, and a Brinly plow
Old 04-26-2010, 08:12 PM
wshytle wshytle is offline
Calvin-
As one of the guys stated you can use it as an additive with the oil but not a substitute. You need to just use a good quality 30w and probably a 10w30 in the winter months. I have an oil can that I dedicated to MMO and I just shoot about 6 or 8 squirts in the fuel tank upon fill-up. I think about an ounce/gallon is the recommended amount so....
The backfiring is probably a timing issue. The best way to correct that would be timing it with an ohm meter. There are instructions in the library (I think). You can also try resetting the points and make sure they end up at .020. This may fix the problem but ohming is suppose to be the surest way.
Good luck....Wayne
Old 04-26-2010, 08:14 PM
I guess the bacfiring issue was for Amigatec.....sorry.
Old 04-26-2010, 08:54 PM
Amigatec's Avatar
I think the timing is very close, it starts very easy, maybe just a turn or two.
Old 04-26-2010, 09:30 PM
aagitch's Avatar
aagitch aagitch is offline
Make sure you let it idle a for a little bit too before shutting it off.
Old 04-26-2010, 09:51 PM
beatty97's Avatar
beatty97 beatty97 is offline
My 129 back fires and timing is right on. If you let it idle for a minute or two before shutting it down it will not back fire
Old 04-26-2010, 10:00 PM
murphycc
Guest
Posts: n/a
I had added it to the gas in my twins and they seem to choke on it...don't do it anymore.
Scott
