Old 08-28-2015, 11:46 PM
CumminSHO's Avatar
CumminSHO CumminSHO is offline
Default Will a 128 Push Blade Fit A 102?
I feel like this is a very simple question but I am a little green when it comes to the wide frame and narrow frame. Is a 128 still a narrow frame? Do they have simular attachment points? There is a blade on the local craigslist for $50 with poor pictures so I cannot tell much about the condition so I was curious if that is a fair price? Thank you for your time and response
1965 IH Cub cadet 102
Brinly 10" plow
42" deck
Front mount snow blower
Front Mount Push Blade
Red Spring Aluminium clutch
Old 08-29-2015, 12:20 AM
The 128 is a wide frame so no, it won't fit.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 08-29-2015, 09:15 AM
CumminSHO's Avatar
Thank you for your response. I felt like it was a simple question and which it was. Thank you for your time.
Brinly 10" plow
42" deck
Old 08-29-2015, 10:27 AM
The blades are the same. The subframes are different, and so is the bracket for the lift rod on the A frame.
Old 08-30-2015, 11:16 AM
CumminSHO's Avatar
Different lift points on the bracket or different bracket?
Brinly 10" plow
42" deck
Old 08-30-2015, 12:00 PM
My mistake. I was thinking the bracket for the spread frames (like the 82 series.) It's the same bracket.
http://ccmanuals.info/pdf/Front%2042...l%20Manual.pdf
Old 08-30-2015, 04:11 PM
CumminSHO's Avatar
Thank you for that post of that manual because that was of great help to visually see it. So the subframe are different? It uses the same lifting system such as for my mule system for my 42" mower deck. I wonder if I could just find a subframe and use that because I have a spring loaded blade with very similar connecting points. The manual was very helpful to see that. Thank you
Brinly 10" plow
42" deck
Old 09-01-2015, 11:14 AM
CumminSHO's Avatar
After doing a little more home work. I was wondering if anyone could post a picture of their subframe and blade on their narrow frame cub. And if possible could I get dimensions of the blade and bracket?
Brinly 10" plow
42" deck
Old 09-01-2015, 11:35 AM
Terry C's Avatar
Terry C Terry C is offline
So did you get the blade off CL? If you don't want to fabricate something you could look for a NF bracket for your blade. I was the other way, I had a narrow frame blade that I made brackets to go on my 149(wf)
You will also have to make a lift bar or modify the existing one
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 09-02-2015, 12:23 AM
CumminSHO's Avatar
I did not get that blade because I have a blade here at home that is very similar set up. That's why I was curious about dimensions to see if what I have would work. What dogs you use for the lifting system?
Brinly 10" plow
42" deck
