Old 08-30-2015, 08:28 PM
cub125 cub125 is offline
Default 1st time fluid filled tires
I decided to give filling the tires on my 100 a try, I bought a adapter and used a transfer pump, It was easy. I was only able to get about 3.5 gallons in each 6-12 tire but I'm sure any extra weight helps.
Cub cadet 125 first one, beginning of addiction
Cub cadet 100 restored
looking for the next one
Old 08-30-2015, 08:46 PM
thats probably all they will hold, a 23x8.50 will only hold 6 gallons and there a good bit bigger.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 08-31-2015, 06:06 AM
kyleb179 kyleb179 is offline
How do you know when it is full? does it make a mess??
Old 08-31-2015, 08:52 AM
I filled them until fluid came out of the bleeder on the fill adapter, or to the level of the Schrader valve. There wasn't much of a mess, I might have lost a cup or two on the floor.
Old 08-31-2015, 11:00 AM
oh nice. I didn't realize their was a bleeder on the fitting. Where did you get the fittings to do it?
Old 08-31-2015, 11:13 AM
jimbob200521's Avatar
This is a good fitting to use available from your local Napa:
http://www.napaonline.com/Catalog/Ca...234_0006476856
And here is a pump to use if you don't have something already. It works with any drill so it'll do just fine for our tire size:
http://www.napaonline.com/Catalog/Ca...028_0361070630
-Ryan
Old 08-31-2015, 04:10 PM
that's awesome, thanks!
Old 08-31-2015, 04:24 PM
Mine looks just like the napa one except it's the tire slime brand, I got it at TSC.
Old 08-31-2015, 10:53 PM
How much air goes in after you fill with fluid?
Old 08-31-2015, 11:18 PM
I filled it to the pressure rating on the tire.
