Old 08-31-2015, 11:09 PM
jonjunk's Avatar
jonjunk jonjunk is offline
Default New to me 782!
Picked up a 782 today from a co-worker for "The Right Price" as I call it. He said he wanted it out of his driveway and knew I liked IHs . Got it home Saturday and took this picture.
The rats nest started on top of the air cleaner and went all the way into the flywheel housing where the cr*p was stuffed tight so the motor wouldn't turn, got it blown out and freed up no problem then proceeded to find it had no spark, ended up being more cr*p inside the points cover grounding them out. Blew out the carb and she is a runner.
Last step is to get the hydro lever and lift lever freed up and tube the back tires.
122 PTO, lift, deck, weights, and chains clist pick
123 headlights no motor came with the 122
Stx38 free acquisition but its the wrong color works great though
Free craftsman gt 17hp Briggs Intek hydro
jonjunk's Avatar
I also degreased the hood and it turned out better than I thought
Old 09-01-2015, 06:59 AM
jeepchicken5000's Avatar
you might be surprised if you take a buffer and some buffing compound to that paint it will make it look a lot better , unless your planning to sell it or redo it that is
1981 cub cadet 682
1966 cub cadet 122
Old 09-01-2015, 09:18 AM
aagitch's Avatar
aagitch aagitch is offline
I was thinking the same. That body looks pretty solid and I bet it'll shine up a bit. My new to me 782 looks exactly the same and I plan on trying to get some of the dull out of the paint once I get it put back together.
Adrian
2072 (789513)
Old 09-01-2015, 09:45 AM
SGragg SGragg is offline
Inactive Member
Congratulations on your "new to you" 782. Looks to be in good shape and a runner to boot! Way to go!
Stanton
1980 IH 782, Kohler M18
IH #1 Cart, original
2015 XT2, Kawasaki 23 HP
Old 09-01-2015, 11:49 AM
Looks like you got a decent tractor, I would wax it by hand since its a single stage and the buffer might take the paint off.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 09-01-2015, 01:38 PM
OldSkull's Avatar
OldSkull OldSkull is offline
Agree 100%
That grease actually act as a rust protection, just clean all surfaces and hand wax with some Carnauba base wax and look the show and shine!
Those I like to use:
1-Mothers Brasilian Carnauba cleaner wax
2-NX Meguiar's liquid wax (I try the Ultimate and the result aren't better)
Top of my list to try: Bilt Hamber double speed-wax (fracking expensive)
Gilles.
1963 100 (red)/in storage
Old 09-01-2015, 01:49 PM
a3v03v0's Avatar
a3v03v0 a3v03v0 is offline
It looks like it is all there. Nice find. Kudos!
Old 09-01-2015, 03:17 PM
TheSaturnV's Avatar
Nice find.
You'll want to have a peak under that belt cover on the mowing deck. I opened mine up just short of too late, and the stiffener plate that holds the 3 pulleys was just about shot with rust.
Old 09-01-2015, 10:17 PM
Terry C's Avatar
Terry C Terry C is offline
Cool find. Don't show it to your coworker after you clean it up and get it running,he will think you owe him
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
