Old 09-01-2015, 08:12 PM
drhntrrmw's Avatar
drhntrrmw drhntrrmw is offline
Default NF Creeper Gear Shaft Seal Question
Is it possible or has anyone replaced the input shaft seal without tearing down the creeper gear?
Thanks,
Rob
_____________________________________________
1968 Cub Cadet 72 w/fenders, headlights, rear grote, hydraulics, creeper, rear weight box, deck and QA-42 snow thrower
Spare NF hydraulics, Brinly harrow, Brinly moldboard plow
Lots of Cub Cadets have come and gone...
Old 09-02-2015, 12:29 PM
sawdustdad's Avatar
I don't see why you couldn't do it. drill a pair of small holes in the seal, screw in a couple small screws and pry the seal out. Make sure the input shaft is smooth before you slide the new seal over it and then seat it with a deep socket. Keep the drill shavings out of the gears...
Old 09-02-2015, 12:44 PM
That's how I would do it but I would make the holes with a nail instead of drilling.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 09-02-2015, 02:27 PM
sawdustdad's Avatar
Yeah, that's actually a better idea. No shavings.
drhntrrmw's Avatar
Thanks, guys.
I got it to work.
What does the spacer behind the poppet look like?
This one doesn't look right to me.
Old 09-03-2015, 12:34 PM
sawdustdad's Avatar
The poppet is the little shift arm that engages the detents on the side of the housing. I've never removed the spacer. But this is what it looks like..
Old 09-03-2015, 06:52 PM
drhntrrmw's Avatar
Thanks for the picture.
I was expecting to see a spacer on the handle shaft between the poppet and the creeper housing.
That looks like roll pin, washer and poppet with space between the poppet and housing? Sound right??
Old 09-03-2015, 08:36 PM
That's what mine look like
