Old 09-06-2015, 10:40 AM
mickb72 mickb72 is offline
Default The Ge-ord
Geo Metro motor, Ford frame, cub transaxle. Homemade alum intake,1bbl rochester carb. Has stock cub welded transaxel. It's made 1 trip down the track with big tires(19 2nd gear too slow). Next trip is gonna be small tire in 3rd(26) then it's gonna come out for a fine spline rear and gears i have once i decide what overdrive to put with them.Started with a truck load of parts (junk). PO had stretched frame and had motor installed. They started it up without a driveshaft and destroyed clutch and throwout bearing arm.(either pushed the clutch to far or the main shaft backed out of the pilot bearing). I had to stretch the hood, raise the dash 4", get new hoses and straighten everything out. It does run really well, if it will stay together. Mike
Old 09-06-2015, 11:33 AM
now thats cool, congrats.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 09-06-2015, 02:57 PM
john hall's Avatar
Thumbs up
Don't know if you'll win any pulls but that is certainly a neatly done machine! I like the Ford tractor theme.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 09-10-2015, 08:02 AM
johns cubs's Avatar
johns cubs johns cubs is offline
That thing is sweet!! Keep us posted as to how she pulls!
John
Old 09-10-2015, 09:30 AM
I'm not at all into pulling (not that I think there is anything wrong with it, just not my thing) but I must say that, that is pretty impressive. It looks like a really clean build, you have every reason be very proud. Good luck getting your gears set up.
