Old 09-08-2015, 11:14 AM
Whoistfd Whoistfd is offline
Default Drive Shaft vibration
The attached file shows a little wear,so replacement is on the way. Looks like a little project my son and I can do
Old 09-08-2015, 08:41 PM
john hall's Avatar
How bad is the end of the driveshaft that goes into that part? Your driveshaft may be shot. Now would be a good time to rebuild the whole driveline if needed.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 09-08-2015, 09:09 PM
The rear bushing is probably shot too.
Old 09-09-2015, 07:43 AM
Default Repair
Just ordered a new Shaft and bearing... I think I got all that I need, is there only one bushing ball?
ToM D
Cub Cadet 1984 782 Hydro, blade, 44 mower
Old 09-09-2015, 07:46 AM
Default Repair
The shaft was pretty bad, so ordered another to replace. Since this is a new purchase, I am looking at it pretty hard to see what may have been neglected over time.
ToM D
Old 09-09-2015, 02:40 PM
john hall's Avatar
Are your rubber mounts and the fan in good shape as well? If I ever pull the shaft I normally replace the spirol pins at the same time. Not trying to spend your money for you, this is just one of those times where a proper repair job can get pricey. The good side of the situation is you won't have to go back into the driveline for a long time. I've pulled drivelines and the only thing salvageable was the fan.
2072 w/60" Haban
Old 09-10-2015, 05:59 AM
I think the only thing that is worth saving is the fan, everything else is suspect, so I agree with you.... when in doubt replace. I think I might do a quick degrease as well so that I am able to keep an eye on things a little better.
ToM D
