Well I got the 105 all done to the stage that it can start doing some work. Snow blower is up and running and the mower deck just needs some some outrigger wheels and a jockey wheel then I can paint both. Tractor runs good but I find after a while it does fume a little bit out of the crank case breather, is that something I need to be concerned about? Any way here some latest pics of my first Cubby.
![]() ![]() ![]() ![]() ![]() Thanks for looking.
Cub Cadet 1968 105 with Spring Assist & 3 point Hitch 42'' Mowing Deck QA36 Snow Thrower 42'' Tiller Snapper 1983 LT1100 ![]() 1967 Mustang Coupe RestoMod
Nice looking 105. Glad you got it running.
1O5 Looks good, should treat you well
Make the best of each day , Todd ![]() Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! |
Looking good! How's that seat? I've been thinking about one like that for my main worker 125.
By the way, do you need a back panel for the fender pan? I've got tons of them. Pm me if you want one.
Ian Mine: 72 w/ k301, 3 125's, 1 w/ hydro lift, 38,42, & 2 48 decks, 2 42 front blades, QA-36a & QA-42a thrower, tiller, lo-boy 154. Also, LOTS of parts. family's:2 105's, 2 106's, 149, 2 lo-boy 154s, Farmall Cub. Non-IH: 1940 JD Model A, 1954 JD 40 U, 1955 JD 40 Crawler, 2 1956 JD 420 U's, both w/ Henry Loader and Backhoe. JD 110. Wheel Horse (model unknown.) Power King 1614. We love our tractors!
Nice looking tractor you have there.
http://www.onlycubcadets.net/forum/s...ad.php?t=42646 70, #1 cart. Brinly Cultivator. Some wheel weights . {125, 126, 2072-Sold~regrettably, 2284 60 inch Haban 325 deck., 451 snowblower, 2182-60 inch Haban 374 deck- "Money Pit", 401 Haban 54 inch dozer blade- rebuilt, 1440-down the road, Another 2182 for parts. Another 2284 for parts. 450 blower. 1812-sold, 2072 w/ Haban 374, and a 2182#3 w/ Haban 325}-------> All SOLD |
105 looks good! Going to be a great worker. As far as some smoke out of the breather, check your oil and the oil level to make sure that you did not overfill. If you are due for an oil change, before you change your oil use some Marvel Mystery Oil (MMO) in the crankcase, run it for a little bit and then drain it and refill with Pure Synthetic Oil (10w30), I find that pure synthetic oil tends to not smoke and it does not thermally break down. You can also run that MMO in your fuel to clean and lubricate the upper chambers of your engine. Follow manufacturer's specs for adding it.
Happy cubbin' Cub Cadet 123
Looks great! Are you testing different front tires? I'm just messing with you.
![]() It's a machine to be proud of. Better start looking for another
Terry O,100,72,102,123,104,124,105 125,129,149,1200,982 (2)2182s w/60in Habans 3225 |
Thanks for the kind comments, I will try that oil set up you mentioned @Cub Cadet 123 and the tires is what it came with, undecided which way to go with them. I could go tri ribs or turf tread or maybe ag tires, going to get some ag's for the rear, I work at a ATV salvage business and we have lots of them.
I like that model so much I have two 125's For snow removal, turfs ( preferably fluid weighted ) with wheel weights plus chains is your best bet. Narrows up front seem to steer better that wides. Ags will be fine for any other work except snow removal ) The only thing I would change on your 105 is to either add bolts to the front mounting holes or the QA pin plates that IHC made back in the day. ( I make them too ) ![]() click for bigger pic The additional pin or bolt will help with reducing flex and strain on the attachment. Jeff |
