OK so I bought a used tiller that needed some work. I have everything done except for removing the tines to replace the leaking seals. This is where I ran into trouble. I removed the bolt that holds the tines on and it won't come off. Soaked in penetrating oil for 4 days smacked it with a hammer, and currently have a puller on it. Also heated with a torch while puller was on and still no luck of coming off. My last idea is to remove engine and handle, and submerg into a plastic barrel for an electrolysis treatment. What do you guys think?
Is it a horse tiller?
I have redone several of the Horse models and and they are great tillers. I usually just put a BIG puller on the tine holder put pressure on it and smack it with a big hammer. I have larger pullers than most auto shops so I can really put the pressure to it.
If you need another one I have a couple that did not sell this spring.
Cub Cadet 1811 undergoing restoration Cub Cadet 1862 waiting for paint Cub Cadet 1050 finally got all the parts bought so next in line behind the 1811 for restoration Allis Chalmers 416 Massey Ferguson MF-8 Brinly 10"plow Soil Mover garden tractor dirt scraper Taking donations for a new bigger garage to hold them all
It's a pony model, basically the same as a horse. Guess I need to get a larger puller and a BFH!!
Yeah it takes a lot of pressure to get it broke loose from the shaft and key. The puller I use is for trucks or heavy equipment bearings. Then I put a half inch inpact on it and it usually pops right off with a couple of strikes from a big hammer.
I got the seal numbers from MTD and ran them through NAPA and saved some on the price. Do not know about the Pony though.
Those or a large two jaw puller
