Old 04-27-2010, 09:40 PM
Amigatec's Avatar
Amigatec Amigatec is offline
Default 129 Tie rods
What other Tierods and draglink will fit this model?
Mine has had the ends welded on.
Pat Benner Haskell OK
Old 04-28-2010, 01:42 AM
young enthusiest's Avatar
Welded??? That's unfortunate.. all WF will fit... I think '82 series will fit as well... I got a set of tie rods here with 4 new ends for $30 If you want them. They are straight, brand new ends on them.
Old 04-29-2010, 10:16 AM
Amigatec's Avatar
I'll take them, PM me the address to send the money to.
Old 05-19-2010, 10:19 PM
Amigatec's Avatar
Well I took the drag link off my 149 to use on my 129 today, and just as I thought, it had been shortened when they welded the ends on. I took an end from a old Snapper RER I have and was surprised to see a nylon bushing on the end. The PO had drilled out the holes in the spindles and installed 1/2 bolts to fit the end that he installed, that made for a loose fit, but with the bushing it was the correct size. Now I know where to get the ends to replace the other with.
The only slop left in the front end now is the saddle were the front axle is pinned in, I will fix that later.
