Old 10-03-2015, 01:03 PM
IHinIN IHinIN is offline
Default Sleeve hitch ripper
I built this ripper to use next year when I have to level out my yard after my new septic system that was installed this summer. I'll likely have to add some weight to it to get it in the ground. It should make for lots of seat time next year. It is 35" wide and the tines are 7" tall.
Old 10-03-2015, 01:19 PM
gt383mag's Avatar
gt383mag gt383mag is offline
nice work looks heavy duty
Old 10-03-2015, 08:32 PM
RedHawCadet RedHawCadet is offline
Looks awesome!
Mark
1971 Model 73 - Hydraulic lift,Fenders,Creeper,Lights,Sleeve hitch and Weights
1967 Model 102- mower
1965 model 70 - weights,rear lift and spring assist
Model 100 resto mod project, rear PTO, hydraulic lift
QA42 snow thrower
42in front blade
Grandpa's F-12 and Super M
Old 10-03-2015, 11:41 PM
Very nice Adam
I think I want one no, I really want one, that would be handy for a couple different things.
Old 10-04-2015, 12:37 AM
Nice work IHinIN
Old 10-04-2015, 09:06 AM
Thanks guys!
Old 10-04-2015, 12:54 PM
Thanks guys!
Looks good
( the sleeve hitch adapter is upside down though )
Old 10-04-2015, 03:50 PM
It looks really good Adam! I hope it works for you though. I just recently tried to set up a cultivator I have in the configuration of a chisel plow...... I about tore the Brinly adapter up. One side would plow in deep while the other side didn't want to. The plow would "walk" side to side because it was being pulled from the center. If it had been a 3pt configuration it would not have been a problem because it would have had a wider and more even pull from the spread on the 3pt arms. If one corner of the ripper snags a root, or a rock, or even just a hard patch it will want to twist the hitch. My experience: I took it off before it tore up my hitch. I actually bent it a little.
Good luck!
Old 10-04-2015, 03:58 PM
mmzullo mmzullo is offline
Nice job!! Are you going to sharpen the front edge of the tooth?
Old 10-04-2015, 09:23 PM
Looks great Adam, nice work.
The sleeve doesn't go "above" the sleeve hitch adapter frame?
Prolly wouldn't bend one of these.
