Old 10-04-2015, 08:41 PM
rdehli rdehli is offline
Default 1812 hydro question
I have broke 2 spring pins in the drive shaft this summer, the ones right next to the hydro coupling, the pins are driving in tight, it is not getting abused I am a pretty easy operator. just think its a little unusual to break these pins. In 20 years of running cubs its the first 2 pins that I have broke. I have noticed that the hydro is a little jumpy espically in reverse. Any ideas?
Old 10-05-2015, 10:38 AM
Darrell Darrell is offline
I bought an 1811 from a guy that kept shearing the pins and when i got it home and working on it there was only two bolts holding the engine to the plate and they were loose. Needless to say , the engine was dancing around.
Something is wrong somewhere , maybe start there first .
Old 10-05-2015, 09:03 PM
All bolts are tight
Old 10-05-2015, 11:03 PM
Mcamp Mcamp is offline
are you using spirol pins? or single wrap? check the springs on your trunnion the inner one when broken causes a jerky hydro.
Old 10-06-2015, 04:01 PM
using spiral pins I will check the trunion too
